查看: 427|回复: 2
[Nspire] Ndless r2021
发表于 2026-1-30 10:29:38 | 显示全部楼层 |阅读模式
于2026.01.29发布
ndless-r2021.zip (2.27 MB, 下载次数: 32)
  1. Ndless r2021 for TI-Nspire OS <= v6.2.0.333
  2. ===========================================
  3. Installing Ndless on your calculator makes it possible to run assembly programs.
  4. Ndless combines an executable loader and utilities to open the TI-Nspire to third-party C and assembly development.
  5. The official website is available on:
  6. ->    http://ndless.me
  7. The source code can be found on:
  8. ->    https://github.com/ndless-nspire/Ndless
  9. A user guide is available online, make sure to read for more installation instructions:
  10. ->    https://tiplanet.org/ndless
  11. A guide for Developers can be found here:
  12. ->    https://ndlessly.wordpress.com/ndless-for-developers/
  13. Pull requests and and issues are welcome!
  14. For more in-depth info, visit the wiki:
  15. ->    https://hackspire.org
  16. Quick guide
  17. ===========
  18. OS 6.2.0.333 <img src="https://i.imgur.com/5nnLNsN.gif" align="right">
  19. --------
  20. Prerequisites: OS 6.2.0.333 on CX II, CX II-T or CX II CAS
  21. * Transfer `ndless_installer_4.5.5-6.2.0.tns` into a folder named "`ndless`" (top-level)
  22. * Transfer `ndless_resources.tns` into the same folder
  23. * Open the installer, press any alphanumeric key and wait
  24. * If it fails or reboots, try again until it works
  25. * Have fun!
  26. OS 4.5.5.79 <img src="https://i.imgur.com/oJGpCsB.gif" align="right">
  27. --------
  28. Prerequisites: OS 4.5.5.79 on CX or CX CAS
  29. * Determine your "boot1" version (needed later).
  30.   * Press `[Home]` > `[5]` (Settings) > `[4]` (Status) > About button.
  31.   * Here is a YouTube [video](https://youtu.be/htr106_ggjg) for this.
  32. * Transfer `ndless_installer_4.5.5-6.2.0.tns` into a folder named "`ndless`" (top-level)
  33. * Transfer `ndless_resources.tns` into the same folder
  34. * Open the installer, press the corresponding key for your boot1 version and wait
  35. * If it fails or reboots, try again until it works
  36. * Have fun!
  37. OS 5.2.0.771 + 5.3.0.564 <img src="https://i.imgur.com/kozAxpP.png" align="right">
  38. --------
  39. Prerequisites: OS 5.2.0.771 or 5.3.0.564 on CX II, CX II-T or CX II CAS
  40. * Transfer `ndless_installer_5.2.0-5.3.0.tns` into a folder named "`ndless`" (top-level)
  41. * Transfer `ndless_resources.tns` into the same folder
  42. * Open the installer and wait
  43. * Have fun!
  44. OS 4.5.3.14 + 4.5.4.48 <img src="https://i.imgur.com/uuO3ue9.png" align="right">
  45. --------
  46. Prerequisites: OS 4.5.3.14 or 4.5.4.48 on CX or CX CAS
  47. * Transfer `ndless_installer_4.5.3-4.5.4.tns` into a folder named "`ndless`" (top-level)
  48. * Transfer `ndless_resources.tns` into the same folder
  49. * Open the installer and wait
  50. * Have fun!
  51. OS 4.5.0 <img src="https://i.imgur.com/ZdWgSCq.png" align="right">
  52. --------
  53. Prerequisites: OS 4.5.0 on CX or CX CAS
  54. * Transfer `ndless_installer_4.5.0.tns` into a folder named "`ndless`" (top-level)
  55. * Transfer `ndless_resources.tns` into the same folder
  56. * Open the installer and wait
  57. * Have fun!
  58. OS 4.4.0 <img src="http://i.imgur.com/mDOg6JG.png" align="right">
  59. --------
  60. Prerequisites: OS 4.4.0 on CX or CX CAS
  61. * Transfer `ndless_installer_4.4.0.tns` into a folder named "`ndless`" (top-level)
  62. * Transfer `ndless_resources.tns` into the same folder
  63. * Open the installer
  64. * Close the installer with Ctrl+W
  65. * Have fun!
  66. OS 4.2.0 <img src="http://i.imgur.com/GS2K9tS.png" align="right">
  67. --------
  68. Prerequisites: OS 4.2.0 on CX or CX CAS
  69. * Transfer `ndless_installer_4.2.0_cx.tns` or `ndless_installer_4.2.0_cascx.tns` into a folder named "`ndless`" (top-level)
  70. * Transfer `ndless_resources.tns` into the same folder
  71. * Open the installer
  72. * Close the installer with Ctrl+W
  73. * Have fun!
  74. OS 4.0.3 <img src="https://i.imgur.com/oEsrtC2.png" align="right">
  75. --------
  76. Prerequisites: OS 4.0.3 on CX or CX CAS
  77. * Transfer `ndless_installer_4.0.3_cx.tns` or `ndless_installer_4.0.3_cascx.tns` into a folder named "`ndless`" (top-level)
  78. * Transfer `ndless_resources.tns` into the same folder
  79. * Open the installer
  80. * Close the installer with Ctrl+W
  81. * Have fun!
  82. OS 3.9.1 <img src="https://i.imgur.com/rT8Ltmy.png" align="right">
  83. --------
  84. Prerequisites: OS 3.9.1 on CX and CX CAS
  85. * Transfer the `ndless_installer_3.9.1.tns` file into a folder named "`ndless`" (top-level)
  86. * Transfer `ndless_resources.tns` into the same folder
  87. * Disconnect your USB cable
  88. * Open the installer
  89. * If you get a message that says "Insufficient memory", reset your calculator and try again!
  90. * Connect the handheld to your computer!
  91. * Close the installer with Ctrl+W
  92. * Have fun!
  93. OS 3.9.0 <img src="https://i.imgur.com/V9U8RSc.png" align="right">
  94. --------
  95. Prerequisites: OS 3.9.0 on Clickpad (CAS/non-CAS) or Touchpad (CAS/non-CAS)
  96. For CX and CX CAS please install 3.9.1.
  97. * Transfer `ndless_installer_3.9.0_classic_new.tns` into a folder named "`ndless`" (top-level)
  98. * Transfer `ndless_resources.tns` into the same folder
  99. * Open the installer
  100. * Close the installer with Ctrl+W
  101. * Have fun!
  102. OS 3.6 <img src="https://i.imgur.com/6cq8g7Z.png" align="right">
  103. ------
  104. Prerequisites: OS 3.6
  105. * Transfer `ndless_installer.tns` and `ndless_resources.tns` into a folder named "`ndless`" (top-level)
  106. * Open the installer
  107. * Press the menu button
  108. * Have fun!
  109. Uninstalling
  110. ------
  111. To uninstall Ndless, simply run the `ndless_resources.tns` file and select "Yes", after which the device will reboot.
  112. Development team
  113. ================
  114. Lead maintainer:
  115.   Fabian Vogt aka Vogtinator - < vogtinator at ritter dash vogt dot de >
  116. Creators:
  117.   Geoffrey Anneheim aka geogeo - < geoffrey dot anneheim at free dot fr >
  118.   Olivier Armand aka ExtendeD  - < olivier dot calc at gmail dot com >
  119. Contributors and testers: Adriweb, AtlassianDell, bsl, cherpixel, critor, Excale, Goplat, hoffa, Jim Bauwens, Legimet, Levak, Lionel Debroux, lkj, sasdallas, satyamedh, tangrs, timmycraft... and many others.
  120. More contributions can be seen on [the GitHub repo](https://github.com/ndless-nspire/Ndless/graphs/contributors).
  121. Ndless is brought to you by https://codewalr.us, https://www.omnimaga.org and https://tiplanet.org
  122. Legal stuff
  123. ===========
  124. Most of the work is covered by the Mozilla Public License, version 1.1 (MPL).
  125. Please read the file [`Mozilla-Public-License-v1.1.html`](./Mozilla-Public-License-v1.1.html) carefully before distributing any part of Ndless, with or without modification.
  126. Some parts are covered by other licenses. Others are in the public domain. These parts are identified by the files `LICENSE.txt` or `LICENSE.html` in the sub-directory.
 楼主| 发表于 2026-2-23 07:31:28 | 显示全部楼层
 楼主| 发表于 2026-2-23 22:21:19 | 显示全部楼层
GMT+8, 2026-7-19 06:37 , Processed in 0.015225 second(s), 22 queries .
